1 members (Peggy M), 321 guests, and 4 robots.
Topics128,169
Posts1,057,102
Members48,463
original #'s:
ignition coil capacitor (No. 1929070) [+ term]
generator capacitor (No. 1911095)[arm term]
voltage regulator capacitor (No. 1917580) [batt term]
so it looks like, NO, any ol one won't do
Also see link below for a Junction black Capacitor #(No 7263920)
http://mars.ark.com/~babytrkr/accman/987187-164.html
Focus,
You can use a coil and wrap the Pos wire around the coil They have them at Radio Shack. Look in the 64 series and ask for a MANAGER who knows his parts should be about 5.00.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I don't know which truck or radio we are dealing with here but I am going to guess it is a Task Force era radio? I don't think that you are going to find the actual GM parts and even if you did, they would probably be dried out and defective.
V-6
I don't understand your comment about wrapping a wire around a coil. Would you care to give us some more detail?
1951 1 Ton Completed
The part I'm speaking of is linked below.
"Effective, easy-to-use RFI fighter. Cut down on RFI (radio frequency interference) with this snap-together Toroid Choke Core. Easily use choke core on a phone, computer, AC, audio and coax cables. No cable cutting necessary - you simply wind it through the core."
http://www.radioshack.com/product/i...58.2032230.2032273&parentPage=family
They seemed to have went up a bit in price but I think you get two to the pack now.
I don't know about some of the Radio Shack products. For someone to mention "coax" as a possible application is pretty bazaar. That just doesn't make any sense. However, thank you for pointing out the reference.
Modelman - that product has no use as a replacement for the truck noise suppression capacitors .... which as 'nix sez, won't be available anymore
Focus - if you could find the particular values, fresh modern parts would prolly be available, but try going without and see if the radio is noisey, might work fine, mine did
I figger as close as you will get is a new condensor for points ign system & use the OE brackets & connectors on it if you are looking for originality.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Take a look at RA450 "Radio Noise Suppressor" on Jim Carter's site. This appears about as close as you'll get to the original looking condenser.
Don
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
Funny that GM listed three or four different part numbers, I would assume they were different values, but JC says that you use three of his at $11.50 each. I would like to know the values of the GM part numbers that Focus listed at the begining of the thread.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I've always been able to get these OE looking capacitors at the local Car Quest. In a pinch I've used a .47uF 200VDC capacitor out of my electronics stock. Doesn't "look" right, but accomplishes the same thing.
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
Someone posted a part number for noise suppression caps that they got from a NAPA store. Danged if I can find it now. I couldn't find it online at the time so I kind of dismissed it as a fluke.
Did anyone ever try their local NAPA and or do you remember where this was posted and what the PN was?
I did a search this morning, but as usual, nothing!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Moderated by  truckernix
