4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
Is there any adapters for converting the old rca pin electrical radio connection to a newer style quick connect jack.
These are found on the +12v lead as well as the speaker connection.
Did not what to cut the original pin style jack and splice a new wire if not nessasary.
nothing I've ever seen - you'll find those pins are soldered directly onto the end of the wire, all ya gotta do is heat it and pull it off, replace with the end of yer choice, but remember you have to deal with the speaker and radio jacks as well as the pins on the wire - for as many times as you need to pull the plugs, why does it matter? on the power wire, just replace it with an inline fuse holder, which is what most I've seen have anyway
Thanks,Red58
What size fuse should be used for the orginal Am
Radio?
the book calls for 7.5 amps [save the whole thing to yer HD as a zip here
Moderated by  truckernix
