| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Is there any adapters for converting the old rca pin electrical radio connection to a newer style quick connect jack. These are found on the +12v lead as well as the speaker connection. Did not what to cut the original pin style jack and splice a new wire if not nessasary. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | nothing I've ever seen - you'll find those pins are soldered directly onto the end of the wire, all ya gotta do is heat it and pull it off, replace with the end of yer choice, but remember you have to deal with the speaker and radio jacks as well as the pins on the wire - for as many times as you need to pull the plugs, why does it matter? on the power wire, just replace it with an inline fuse holder, which is what most I've seen have anyway
Bill | | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Thanks,Red58 What size fuse should be used for the orginal Am Radio? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the book calls for 7.5 amps [save the whole thing to yer HD as a zip here Bill | | |
