| | | Forums66 Topics128,108 Posts1,056,568 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | I recently removed the radio on my truck and it does not appear to be original. I don't really have the extra money to buy a repro for $600 and I don't want to spend my time trying to find a used one to be fixed up. What I was wondering was if there was some kind of plugs or something that can be used to fit in the holes in the dash. On oldgmctrucks.com, I saw some of the original factory photos and there was one with the two holes on the side and the large rectangle in the middle plugged with something. I think it was metal and it was painted the same as the dash. Is there anybody who knows about these? Should I just try to make my own? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | justin, the item that you are describing is called the radio delete plate. These turn up all the time on eBay. I would think that if you put an ad in the parts wanted, someone will respond. I think that they usually go for less than $20. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | You shouldnt have a problem finding one, is the delete panel for a GMC the same as a Chevy?
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, they are the same part. They are in fairly high demand considering all they do is plug a hole. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I need to find one. The PO took it out to put in the truck he was fixing.
So, I agree they are in demand.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Old blu I have one that I took out of my 53 3100.PM me if you want it. | | |
