5 members (Southerntruck, RoadsScholar, 50Chevy3100, NorthCoast3800, Gray_Ghost), 118 guests, and 3 robots.
Topics128,100
Posts1,056,514
Members48,448
#326868 01/01/2007 7:44 PM
I recently removed the radio on my truck and it does not appear to be original. I don't really have the extra money to buy a repro for $600 and I don't want to spend my time trying to find a used one to be fixed up. What I was wondering was if there was some kind of plugs or something that can be used to fit in the holes in the dash. On oldgmctrucks.com, I saw some of the original factory photos and there was one with the two holes on the side and the large rectangle in the middle plugged with something. I think it was metal and it was painted the same as the dash. Is there anybody who knows about these? Should I just try to make my own?
#326869 01/01/2007 10:19 PM
justin,
the item that you are describing is called the radio delete plate. These turn up all the time on eBay. I would think that if you put an ad in the parts wanted, someone will respond. I think that they usually go for less than $20.
1951 1 Ton Completed
#326870 01/02/2007 10:33 PM
You shouldnt have a problem finding one, is the delete panel for a GMC the same as a Chevy?
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#326871 01/03/2007 3:29 AM
Yes, they are the same part. They are in fairly high demand considering all they do is plug a hole.
#326872 01/13/2007 10:43 PM
I need to find one. The PO took it out to put in the truck he was fixing.
So, I agree they are in demand.
Dennis
#326873 02/16/2007 2:30 AM
Old blu I have one that I took out of my 53 3100.PM me if you want it.
Moderated by  truckernix
