7 members (FAST55, Otto Skorzeny, dt235sd, FishinToms53, 3B, Rusty Heaps, 1 invisible),
95
Mod | | | Forums66 Topics128,115 Posts1,056,632 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i know these original radios are pretty basic, but im not sure which of the three prongs to attach the 12volts to. any one familiar with these? i immagin one is for the power, and the other two for the speaker. any help would be appreciated | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Murdoc, look at the last two replies in this thread. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=42;t=000101
I don't have the data sheets for your radio but the explanation above should be helpful. I don't know if your radio has separate speaker connectors or whether it has a separate lead for the dial light. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The one for 12v power is slightly offset, the other two are speaker + & -. Ground is thru the mounting. Brian | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | thanks guys, helpful as always | | |
