| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 5 Junior Member | | Junior Member Joined: May 2006 Posts: 5 | I've got a 64 Suburban with an original radio that works very well until the temp drops to about 40. This radio can be heard from a long way off. If I let the cab warmup to 70 or so it will just squeel for about a minute but much less volume? I had a local "radio guy" look at it but i don't think he knows a whole lot more than I, at least about this problem. Sounds like you have lots of experience with these older radios. Any help would be greatly appreciated. Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is a way too modern for me. I would think that it is all solid state. Maybe someone else could chime in here. | | |
