| | | Forums66 Topics128,180 Posts1,057,141 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Are there still parts available for the old vucuum tube radios? I picked up one at my favorite salvage yard for $20 and would like to see if I can make it work again, mainly just for the challenge of doing it.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | see here for the manual , and see the radio tech tip , also this thread buried way down, which I'll get back to soon, I hope first thing you'll need to do is replace all the capacitors, available here - then check the heater filaments on the tubes, and if they're open need to search for the tubes - available from suppliers, including guys that have e-bay stores - if it's the TF radio good luck and keep us in the loop! Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Longbox, there are many parts available for these old radios. Resistors and capacitors are widely available as they are still produced. Most of the tubes are not produced anymore but there are many sources for used and NOS ones. I buy most of my tubes on Ebay and I like to buy them from vendors that have a tube tester and offer some type of compensation if they are defective.
Have a look at the radio tip that Red58 mentioned. There are some hints in there that could save you some grief. Your particular radio is quite simple and the the design gives excellent access to the components.
Finally, you can post here any questions or problems that you have along the way and they will be answered. I can walk you through the procedures for diagnosng faults.
Welcome to the radio forum and thanks for posting. | | |
