| | | Forums66 Topics128,050 Posts1,055,758 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Anyone know if there is a difference between gmc and chevy radios other than the dial logo?
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Grant, if you are talking about the AD radios, there is no difference other that what you have mentioned. However, if the vibrator has been replaced with a solid state one, it will be specifically for negative or positive ground. Nothing else in the radio is polarity sensitive. | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Thanks, I did mean for a AD radio. I know you can get a Chevy to work in a GMC and it will look the same from the dash if you change the dial. I just wondered if they are the same chassis and components. Don't know why it matters but I was looking to buy one for my GMC and thought I might as well get one from a GMC
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Grant, I imagine that you know this already but you can buy the dial from many of the vendors. You can buy the dial, bezel, pushbuttons and knobs. The replacement dials have a different arrangement of the numbers and they don't line up with the actual tuner, too well. Other than that, they look really nice. | | |
