0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#32635 02/03/2004 2:13 PM
Have been planning to put 86 S10 T5 in my 48 5 window with 235. This weekend I lost a rod in the 235 ruining the crank. I have an early 70s 292 I think I will put in the 48, will the S10 T5 bolt up to the 292. The T5 was used in an S10 pickup with 2.8 V6 engine.
I know the 292 will use any tranny the V8s use.
1948 Chevy
5 window
"6" powered
#32636 02/03/2004 10:04 PM
Yes, the T-5 will bolt up to a 292 with a manual bellhousing but it may not last long unless it is beefed up or driven gently. The T-5 doesn't handle that much torque.
Paint & Body Shop moderator
#32637 02/04/2004 3:22 PM
I am presently attempting this swap into my '54, only with a 250. I am using a v8 bellhousing from a '55'59 Chevy truck and it is 1/2" shallower than the 235 one that I had my T-5 attached to. When I get a clutch set up in place, I will be able to see what mods (if any) will need to be done on the T-5 or bellhousing. I think that any mods will be minor in nature.
r
Every once in a while, life gets a little more surreal.
