0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32625 06/10/2002 5:57 PM | Joined: May 2001 Posts: 13 Junior Member | | Junior Member Joined: May 2001 Posts: 13 | when i bought my 53 1/2 ton it had a 235 ci engine made in mar of 1955 already in it...is there a way you can tell if the engine came originally w/ the truck or if it came from a car?? mahalo | | |
#32626 06/10/2002 7:54 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | I believe I have heard: solid lifters = truck, hydraulic lifters = car. You'd have to remove the side covers to find out.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#32627 06/10/2002 9:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You also need to pull a pushrod and pull a lifter out of it's bore and look at it carefully. My '57 truck 235 has lifters that look like hydraulic in almost every way but they are actually solid.
#32628 06/10/2002 9:48 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | 235 CAR
292 TRUCK
Lifters ----SMIFTERS A car motor is a car motor even if you put it in a truck to try an foolyah
228,248,270,302 Truck motors!Never put in a car unless you count the guys that wanted to go fast! | | |
#32629 06/11/2002 11:55 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | May I ASSume this is more Chevy bashing? I'm sure you know that 235's and 292's are from different era's.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#32630 06/11/2002 2:28 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Doesn't matter. When Proffitt chases his medication with STP, he starts mumbling and ranting about going to Paris with a pocketful of shimstock to see the truck motored cars or something. :p
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#32631 06/11/2002 4:45 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Chip's broken the code!!! Actually Chevy's are a bit better than [email protected] are CAR motored! Actually,Some of the time this ISN'T me but Phat using my handle!!! Don't ever take any-o-this too seriously....it'l get you!!! | | |
#32632 06/11/2002 5:35 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | IT wouldn`t want me!
#32633 06/12/2002 5:08 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | 'S O.K. ~ Jim's getting a new nurse soon , she'll make sure he takes _all_ his meds :-) .
Jim , Shirley says maybe breakfast @ Jack's this sunday ? my e-mail is out yet again .
I'm sneaking on this list for a hot minute , sine it loads SO darn SLOW they'll no doubt catch me and restrict me again :-^ .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#32634 06/12/2002 6:15 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Car or truck engine? Check the serial numbers. If it's original, the car had a phenolic timing gear, the truck had aluminum. They used phenolic in the cars because they were quieter. For Jim's amusement, the aluminum gear was stronger, making the 235 a truck motor!  Like he said, don't take it seriously.
Fred 52 3600 69 C-10
