1 members (baldeagle),
87
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | ok i have looked through old posts and through how to make a bed. i read somewhere ,someome had the correct dem. for the wood spacer blocks for the AD truck. but i cant find that posting. could someone please tell me the mesurments or lead me to where to find them? thanks
gotta love old trucks
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | 2 1/4" square by 2 5/16" tall . | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 |
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | 53chev: Sometimes the frame is tweaked a bit and the block height needs to be adjusted. The rear sill bracket is 4 inches tall. Each of the other mounting points needs to be just high enough to make the tops of all the cross sills level with each other and the top of the rear sill wood mounting surface. Shave your blocks if necessary to get everything level. Also, check the splash apron clearance to the bed side as that is controlled by the mounting block height.
Mar-Ktech | | | | | Joined: Sep 2007 Posts: 27 Apprentice | | Apprentice Joined: Sep 2007 Posts: 27 | I just attached my bed this weekend using the 2 5/16" tall blocks I purchased online. They did not raise the bed enough to clear the top of the shocks. I bought some Maple and cut new ones at 3". This will give me some trouble when I go to install the running boards which I don't own yet. I'll have to jump that bridge when I get to it. I noticed that some online companies sell mounting pads for each block as well as the rear sill. The site I bought from only sold pads for the rear sill so I cut some of my own. 51 chevy 3/4 ton Martin | | |
