0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#32625 06/10/2002 5:57 PM
Junior Member
Junior Member
when i bought my 53 1/2 ton it had a 235 ci engine made in mar of 1955 already in it...is there a way you can tell if the engine came originally w/ the truck or if it came from a car?? mahalo
I believe I have heard: solid lifters = truck, hydraulic lifters = car. You'd have to remove the side covers to find out.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
You also need to pull a pushrod and pull a lifter out of it's bore and look at it carefully. My '57 truck 235 has lifters that look like hydraulic in almost every way but they are actually solid.
Paint & Body Shop moderator
235 CAR
292 TRUCK
Lifters ----SMIFTERS A car motor is a car motor even if you put it in a truck to try an foolyah
228,248,270,302 Truck motors!Never put in a car unless you count the guys that wanted to go fast!
#32629 06/11/2002 11:55 AM
May I ASSume this is more Chevy bashing? I'm sure you know that 235's and 292's are from different era's.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
Doesn't matter. When Proffitt chases his medication with STP, he starts mumbling and ranting about going to Paris with a pocketful of shimstock to see the truck motored cars or something. :p
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Chip's broken the code!!!
Actually Chevy's are a bit better than [email protected] are CAR motored!
Actually,Some of the time this ISN'T me but Phat using my handle!!!
Don't ever take any-o-this too seriously....it'l
get you!!!
IT wouldn`t want me! grin eek
V
V Offline
'S O.K. ~ Jim's getting a new nurse soon , she'll make sure he takes _all_ his meds :-) .
Jim , Shirley says maybe breakfast @ Jack's this sunday ? my e-mail is out yet again .
I'm sneaking on this list for a hot minute , sine it loads SO darn SLOW they'll no doubt catch me and restrict me again :-^ .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Car or truck engine? Check the serial numbers. If it's original, the car had a phenolic timing gear, the truck had aluminum. They used phenolic in the cars because they were quieter. For Jim's amusement, the aluminum gear was stronger, making the 235 a truck motor! grin Like he said, don't take it seriously.
Fred
52 3600
69 C-10
