1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#326037 05/25/2007 3:26 PM
Okay,maybe I'm dumb,but how do I reach and remove the top bolt from the tail gate hinge when the nut is inside the stake pocket. I don't seem to have a thin enough open end to slide up in there. There is some sort of a thin brace welded inside the pocket.
Drew
Junior Member
Junior Member
The top nut is what I call a "capture" nut--it is held in place by a weld or clip. You shouldn't need a wrench, just back the bolt out from outside.
"Age is only relative- - -It's just that some of us have more relatives than others"
Duh. :o Thanks cooterhead.
Drew
