| | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Okay,maybe I'm dumb,but how do I reach and remove the top bolt from the tail gate hinge when the nut is inside the stake pocket. I don't seem to have a thin enough open end to slide up in there. There is some sort of a thin brace welded inside the pocket.
Drew
| | | | | Joined: Mar 2007 Posts: 35 Junior Member | | Junior Member Joined: Mar 2007 Posts: 35 | The top nut is what I call a "capture" nut--it is held in place by a weld or clip. You shouldn't need a wrench, just back the bolt out from outside.
"Age is only relative- - -It's just that some of us have more relatives than others"
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Duh. :o Thanks cooterhead.
Drew
