Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
Finally finished our 53 bed this week. My nephew came out and sprayed the Vortex bed liner on Sunday. We sprayed 3 sides and the bed strips. Forgot just how long it takes to put all those nuts and bolts back in. The Cherry and Purpleheart came out OK. Put some photos on photbucket if you would like to see the finished product.
http://s159.photobucket.com/albums/t160/sworden73/
Wow, that is beautiful! cool My brother had commented to me a few years ago when I was building my '82 Chevy stepside that I should use purple heart. Couldn't quite picture at the time what it would have looked like, so I chickened out & went the easy route with oak. ohwell
Gonna have to keep that in mind when I get to the point of doing that. Great job!
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
Beautiful wooden bed; diamond plate w/ diamonds couldn't look any better.
tomo
Thanks, Hawk and Tomo. It was nice to get it done. Now to fire up the crate engine for the first time.
Hey Coach, that is a thing of beauty. I know from experence that there is a lot of work there. I like the way the purpleheart goes with the color of your truck.
Keep up the good work
George
Coach,
As a carpenter by trade I love the way it looks!! Great job
Dan
That bed looks amazing. I really hope that you used a UV block type coating. That purpleheart will darken to almost black and the cherry to a nice chocolate brown in the sunlight. I know this from having built a harp and from both woods and other furniture at other times that got to sit in a window. The part that was in the sunlight is definately darker than the other. Just thought I would give a word of warning to keep it covered if you can.
I used two coats of Watco teak oil, which has uv blockers, plus 7 coats of Helmsman spar urethane that also has uv blockers. I know the Cherry will still darken as I have built many cabinets out of cherry wood. First try at purpleheart, the lumberyard man said that the teak oil worked for his customers that used purpleheart in their boats. Only time will tell. I do know that if it gets too dark that I can run it thru the planner again to take off the darkness from the purplehart and restore the purple color. Would definitely be a project to put 7 coats of urethane back on it again though. I guess I will just have to see what happens. Total cost of the bed was $178
