7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 25 Apprentice | | Apprentice Joined: Apr 2005 Posts: 25 | After applying the first coat of clear satin finish to my oak bed wood I have decided I would prefer a gloss finish. Can I apply coats of gloss over the satin. I am using Minwax Helmsman Spar Urethane. Thanks | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would say yes. I just did it with satin over gloss lacquer yesterday. I would think urethane gloss over satin would work as well. Try it on a scrape piece first. It is a finishing technique that is supposed to make the finish look like it is deeper or thicker.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Lightly sand that first coat with 220 sand paper. Did you stain the oak? If you did, be careful not to sand into the stain. You can sand most of the satin off if you didn't stain the wood. You should sand between coats of Spar anyway. This will get rid of bubbles and crap that stick to the urethane. I just finished putting 7 coats of Helmsman on last week. Sanded between every coat. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have a question about sanding between coats: How hard to sand? Make it smooth or just to remove stuff that stuck? Sorry to hyjack but it seemed to be a quick question to ask. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | You have to rough the surface to get the next coat to stick better. It will look dull and small sanding marks in the surface. I sand the entire board, both sides and edges. The next coat will cover these as long as you stay with 220 grit for sanding. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. Dumb question but do you sand with 220 sandpaper or 000 steelwool? A local wood person told me to use the steel wool but I've never refinished anything wood before. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | 220 sandpaper. I have used steelwool 0000 to take down a gloss coat to semi-gloss. But you are trying to get out rough spots, impurities and get a flat level surface. Sandpaper is better, plus, some wood reacts to steelwool fibers. To be safe use sandpaper. Just get the surface level and don't sand thru to the stain if you are using any. You will load the paper up pretty fast with white residue from the urethane. Change paper often. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | |
