Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Donf, Otto Skorzeny, Youngin' Tut 59, TooMany2count, 1 invisible), 127 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
Apprentice
Apprentice
Just did my '58 1/2 ton bed with painted pine (POR then enamel) and SS angles, bolts and strips. This is not a show truck!
My opinions on Mar-K bed wood hardware:
A+ : web site, packing and shipping
A+ : polished SS angles, strips, & bolts
B- : pine. 1 board cupped, mixture of qtr & flat sawn. All boards had planer marks and slight dings.
before... plywood with flat metal strips on top:
http://www.filehigh.com/serve/8290/378149.jpg
after... MAR-K stainless & painted pine:
http://www.filehigh.com/serve/8290/378148.jpg
http://www.filehigh.com/serve/8290/378152.jpg
lookin pretty slick Phil, looks darn showy to me!
Looks great, I'm still undecided as how to put a clear finish on mine, boards should be here any day. real nice job Phil
Popa Kents Body Shop
Looks great Phil. You did a nice job on the bed. I just applied my 7th coat of Spar Urethane this morning. Now to let it dry thourghly for the next 72 hours. I will post some photos after we get it back into the bed. Frank
Phil, I went to the Mar-K site and read their description of their bed wood. I think I would be a little upset with them if my wood arrived as you say yours did. It says that the wood is sanded and ready to finish. Leaving planner marks and dings doesn't sound like ready to finish wood. I would expect some final sanding on boards purchased in the ready to finish state but not as you described. To have mixed flat and quarter sawed wood is not good either, especially if you wanted the grain to show. I see you went with a dark look on your boards, at least this would cover up the different grain patterns. You did a very nice job on your bed.
