2 members (Rnl364, baldeagle),
50
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | Has anyone recently purchased a set of bed boards for a 1950, or by chance have taken pictures of their bed. I am thinking I would like to make my own bed out of oak, but have absolutely no pattern to go off. Any help would be appreciated. Thanks, Scott
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I think there is a tech tip here on this site for that, look under "tech tips" first.
Mike | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | thanks for the help. I too am still in that deciding stage as to whether or not I want to use wood or corrugated steel. Guess time will tell
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I made the planks for my 55 2nd with hand tools.
I bought the yellow pine locally, cured it in the garage for a period of time. Cut them to width with a table saw, used a router for the edges, skill sawed the grooves, then cut them to length. I just recommend that the metal strips be a little higher than the wood so when you slide sheets of stuff down the floor that it goes in smoothly (and doesn't scratch you cool floor).
I bought the metal strips at a swap meet for one of the vendors. Saved shipping costs.
I used Valspar polyurethane that I bought locally at Lowes for a finish, but you will find that everyone concocts their own favorite encapsulating solution. You may like them black.
All the bolts were bought locally in a box. I did not off-set the plank bolts and did not find it to be a problem.
Have fun. That is why we do this and gather here.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | did you happen to keep your plans when you cut your boards? or any plans at all from when you built your bed?
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I will look around the garage and see what I have. I pulled them off a website but cannot remember which.
And. I will need to build bedwood for my 53 so sometime this year I will be back in business doing this again. Red58 posted two good sites with dimensions. I plan to use them when I get ready for the 53.
