9 members (Hush, crenwelge, RoadsScholar, Gdads51, R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, Gray_Ghost),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | For the 54 bed, the cross sills are at 2-1/2", 26-11/16" and 53-11/16" measured back from the front bed panel or the front edge of the wood, and there should be an angle strip bolt hole at each of those locations. There should be a bed to frame bolt hole in the frame at the 53-11/16 cross sill. The bed does not have a bolt to the frame through the 26-11/16 cross sill.
As stated in this quote from another post; "The bed does not have a bolt to the frame through the 26-11/16 cross sill".
There is a hole in the top of my frame at this location. It is smaller than the bed to frame bolt holes. Is this hole used to bolt the rubber pad sill support to the frame at this location. Or is there only 3-pads per side on a 54? | | |
