0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I am remvoing onl bed in prep for rebiuilding. The angle strips seem to be welded or attached to the side of the box. How do I get these free from the sides?
b51r
| | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | The bed angle strips are spot welded to the sides. You will have to drill out the spot welds to remove them.
Having removed about a thousand spots on a recent project I strongly recommend the Blair roto broach type tool.
It cuts a circular plug that is easy to control and fast.
Paul | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | Wisner955 has the straight skinny. Invest in a spot-weld drill and take care not to distort the bed side material by prying/twisting/pulling the angle strips away from the sides!
Everything is different now...
