6 members (NJC, KCMongo, 59 fleet, Brian Moore, 42465967, Wally / Montana), 81 guests, and 2 robots.
Topics128,034
Posts1,055,539
Members48,425
#325438 10/11/2006 6:15 PM
Just searched the archives looking for bed wood dimensions that would be correct for my 1938 HC
1/2 ton stepside. I work in a hardwood mill and have access to ash, hickory, oak, hard maple, lyptus, etc. and would like to mill my own bed components. I can't seem to find any such specs for my year model. the original bed wood in my truck has long since turned to sawdust. Any help would be appreceiated.
"You are only young once, but you can ALWAYS be immature!"
1938 Chevrolet H/C 1/2-Ton
#325439 10/11/2006 8:22 PM
Finished wood thickness is 3/4 inch. All boards have a 1/4 in. deep rabeted edge 3/4 in. wide on both sides except the two outboard boards that have only one edge rabeted. Wear irons fit in rabeted areas and just set proud of wood top. If you have replacement wear irons measure height and adjust the rabet depth to fit. There were 6 boards in bed. Spacing boards with enough room to provide clearance for wear iron carrige bolts. Most original beds were yellow pine. White oak being closed cell works real good and takes a nice finish.
34 & 35 trucks are the greatest
