0 members (),
137
0
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've been keeping track of the bed finish test at the Mar-K site, seems that black Por-15 has held up the best. What I was thinking was would clear Por-15 work as well? I'm looking for possible opinions before i tear mine apart to redo it.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | bump
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ok, I'll opine - I think the black would have better UV protection, the clear would be more affected by UV
Bill | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | In doing the research for the finish testing we came across the http://www.smithandcompany.org/ website that describes the CPES we used in the test. There are several interesting articles on what it takes to protect wood from the elements. Regarding the difference between pigmented and clear products protection, the pigmented product designed for exterior use blocks UV and the clear products work by absorbing UV. After a time, the clear has absorbed all it can and it begins to break down. The pigmented (black) product continues to protect as long as the coating film is intact. It appears that clear can provide good protection until its absorbers quit working, then it needs to be sanded and recoated. Note that not all pigmented products provide UV protection. Mar-Ktech | | |
