| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 10 Junior Member | | Junior Member Joined: Jan 2004 Posts: 10 | mounting my box today on a '48 chev 3/4 ton. everything i've read is that the 2 long bolts go at the front right through the frame, but only the right side has a hole through both flanges of the frame. has anybody else run into this problem? | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Mine both go all the way through. Mine is a half ton but should be the same. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | This is from our bed assembly instructions for the 47-51 Long Step:
"The long 3/8"-16 X 12" bed-to-frame bolts are used at the front pair of holes near the front bed panel." | | | | | Joined: Jan 2004 Posts: 10 Junior Member | | Junior Member Joined: Jan 2004 Posts: 10 | Thats what I thought but theres no hole thruogh the bottom flange on the left rail. It looks like the rear bolt on the right side could go through both flanges but then the bolt seems to long. For now I just bought another 6" bolt and put it in that front left hole. Thanks for the replys | | |
