5 members (Woodcmiami, 6inarow, Bill Hanlon, 59 fleet, 1 invisible), 90 guests, and 2 robots.
Topics128,035
Posts1,055,556
#325373 09/09/2006 8:41 PM
I
Junior Member
Junior Member
I Offline
mounting my box today on a '48 chev 3/4 ton. everything i've read is that the 2 long bolts go at the front right through the frame, but only the right side has a hole through both flanges of the frame. has anybody else run into this problem?
#325374 09/11/2006 6:38 PM
Mine both go all the way through. Mine is a half ton but should be the same.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#325375 09/12/2006 4:19 PM
This is from our bed assembly instructions for the 47-51 Long Step:
"The long 3/8"-16 X 12" bed-to-frame bolts are used at the front pair of holes near the front bed panel."
#325376 09/13/2006 3:11 AM
I
Junior Member
Junior Member
I Offline
Thats what I thought but theres no hole thruogh the bottom flange on the left rail. It looks like the rear bolt on the right side could go through both flanges but then the bolt seems to long. For now I just bought another 6" bolt and put it in that front left hole. Thanks for the replys
