1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
I'm having trouble describing this, but the offset washers that the long bolts go through on my '48 half-ton need to be set up, and I need to know, in terms of the hands on a clock (from the rear view of the bed), toward what number does the largest side of the washer face? At 12, toward the cab?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
You are correct, the large side of the washer goes toward the front of the truck. http://www.mar-k.com/mtgholes_3-8_ofst.pdf Check figure 4 step 4 for a diagram. I expect it would work either way, but the original trucks I have seen are like the diagram.
Mar-Ktech
Thanks!!
1948 Chevy 1/2-Ton
