When you put that finish on your bed woo, put the finish on the sides and ends when you're finishing the top of the boards. If you're an amateur like me, you're bound to get a few drips from doing the ends, and it's less visible when the drips show up on the bottom. Yes, you can sand them off, but you risk going through the finish to the wood itself, and lightening any stain you used.
