4 members (Shade Baby, 1955 1 Series, 55shaker, Wally / Montana), 119 guests, and 4 robots.
Topics128,139
Posts1,056,448
Members48,441
#325101 01/26/2006 3:32 AM
Has anyone used Rhino Liner in the bed of their truck? I have also heard of people spraying the inside of their fenders with this stuff too. Would you have to spray the bottom as well to preserve the wood?
#325102 01/26/2006 5:44 AM
i have not heard of anyone doing it, i would wonder about the wood rotting from the inside if it got even the littlest bit of moisture. i am not sure how it would work, someone more knowledgable than me will probably reply soon.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#325103 01/26/2006 5:00 PM
It doesn't help you right now, but the next Mar-K wood finish test series will include a few samples with bed liner on the wood. This question comes up from time to time, but I haven't heard long term results from anyone that has actually done it.
Anybody out there with personal experience using bed liner coating on their bed wood?
Mar-Ktech
#325104 01/26/2006 7:04 PM
Junior Member
Junior Member
A friend of mine has had it on his trailer wood for the last few years. Makes a great no-slip surface and it appears helps preserve the wood too. I have a womanized wood bed on my trailer and it's holding up great too...
Keep on Trucking
#325105 01/26/2006 9:47 PM
Mar-Ktech,
I am just researching now. I won't get to my bed for another 6 months. When do you plan to do the test with the liner?
#325106 01/27/2006 1:07 AM
I highly recomend LINE-X , lifetime guar.not cheep but the best for metal , wood, aluminum, fiberglass, u name it. under runningboards, boat bottoms, trailer beds, i've seen whole trucks(2001 DODGE EXT CAB)done bumper to bumper. Good luck! bowties
#325107 01/27/2006 5:06 PM
Quote
Originally posted by jomichael:
Mar-Ktech,
Bedliner finishes are really tough and for a truck that gets used, may be the best option for durability. I am anxious to see how we can get a nice looking bed floor that also has the long life needed to be practical.
Any suggestions? Would you coat the bed strips and wood after installation? It seems that the wood should be coated before installation to get full coverage. Maybe the grooves should be cut wider than normal to accomodate the buildup of lining material in the grooves.
We plan to do more testing beginning this summer. It will include some penetrating oil products and the bedliner type products. The problem is, some of the finishes we are testing last a long time and it may take years of exposure before we know results. I like to run tests until a product fails, then describe the results.
If any of you want samples of the pine or oak we use for bed wood, contact our sales people. Sample sizes are available for a shipping charge only. That way you could start to conduct your own test and see how a bedliner finish would look on your bedwood.
We will try to publicize the tests, but keep checking the website www.mar-k.com for information about the testing we may be doing. We will of course mention it in the forums also.
Mar-Ktech
