2 members (RoadsScholar, 1 invisible), 154 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#32449 05/06/2005 4:19 AM
Hi all, what is the correct way to prime the oil pump on a newly rebuilt engine? A friend of mine says you turn the engine over with the ignition off until oil shows up in the rocker arms. That doesn't sound right to me, I thought the pump had to be primed somehow. The engine is a 350. I need some help here because I'm hoping to fire her up tomorrow. Thanks, Don
#32450 05/06/2005 5:09 AM
Some use a the shaft from an old distibutor chucked in an electric drill and run until you get oil pressure.
#32451 05/06/2005 2:11 PM
You will know when you get preasure the drill will tell you!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#32452 05/06/2005 3:44 PM
kwf Offline
If you don't have an old distibutor, Summit Racing or JEGS sells a tool just for priming engines.
#32453 05/06/2005 3:59 PM
8
8 Offline
I found an old rod with a flat end in dad's junk (er I mean stuff) that I chucked in the drill. Whatever you find that will fit the drill and engauge the pump will work fine. Like Brian says, you will know when the pump gets primed. I also had dad check the oil guage while I was pumping.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#32454 05/07/2005 12:48 PM
Thanks guys for the suggestions. I rented a tool and ran the drill until the pressure was up. Worked great. Don
