2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32439 04/26/2002 1:14 AM | Joined: Apr 2002 Posts: 1 Junior Member | | Junior Member Joined: Apr 2002 Posts: 1 | i'm looking to find out what motor is in my 1,1/2 ton? a straight six, casting #3851659, spin on oil filter (front right), dist. closer to front than fuel pump(pump in middle) timing mark on pulley, paper air filter. | | |
#32440 04/26/2002 1:20 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | dollars to donuts, it's a 261. | | |
#32441 04/26/2002 1:21 AM | | Anonymous Unregistered | | Anonymous Unregistered | 63 or newer 292 truck engine . . . good motor, can be made even better with a little head work, intake and exhaust manifolds and cam. Can be built to be a torque monster for hauling or be made produce power all the way to 7000 rpms. Several vintage racers / drag cars turn in the 10's with that motor. [img] http://www.inliners.org/race/ride11_5.jpg[/img] | | |
#32442 04/26/2002 1:41 AM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | a picture is worth a thousand words that one is worth a bit more thanks ken
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#32443 04/26/2002 5:48 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I never saw a race car with a canopy on it before!
Fred 52 3600 69 C-10
#32444 04/26/2002 6:12 AM | | Anonymous Unregistered | | Anonymous Unregistered | Helps with front end lift . . . :p | | |
