0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#32436 08/20/2004 11:27 AM
I'm in desperate need of flex plate bolts to bolt flex plate to crankshaft for a 1956 235. the engine builder had to weld nuts to to the originals to get enough leverage to remove them.
#32437 08/20/2004 3:05 PM
twe56,
What is the size of the original bolt (diameter, length, head size and thichness)?
Mr. Gasket might have what you need.
What is you type of vehicle and type of transmission ? (Powerglide or HydraMatic? You refer to the flexplate rather than a flywheel).
Tim
#32438 08/20/2004 3:11 PM
Thanks for the info. The vehicle is a 56 Chev sedan -- with a powerglide --
