1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32436 08/20/2004 11:27 AM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | I'm in desperate need of flex plate bolts to bolt flex plate to crankshaft for a 1956 235. the engine builder had to weld nuts to to the originals to get enough leverage to remove them.
Thanks | | |
#32437 08/20/2004 3:05 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | twe56, What is the size of the original bolt (diameter, length, head size and thichness)? Mr. Gasket might have what you need. What is you type of vehicle and type of transmission ? (Powerglide or HydraMatic? You refer to the flexplate rather than a flywheel). Tim | | |
#32438 08/20/2004 3:11 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Thanks for the info. The vehicle is a 56 Chev sedan -- with a powerglide -- | | |
