| | | Forums66 Topics128,056 Posts1,055,792 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32365 02/09/2005 8:47 PM | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I have a few more questions. The 292 I am going to get is not complete. It is missing the fan, carburetor, flywheel and probably some other small things I can't think of. I think the carburetor is larger with a different bolt pattern than the smaller ones in this series, is this correct? Also, someone told me they thought the flywheel was different than the smaller series. It this is true, can another flywheel from the 230 or 250 be made to work? I am not too concerned about the other missing parts since I think I can come up with those rather easily. The carburetor and flywheel may be another matter. Thanks for the help. | | |
#32366 02/09/2005 10:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The flywheel can be made to work by drilling the bolt holes out to 1/2 inch& getting 292 bolts. The other carbs will work but lose a little power because of smaller bore & venturi. Usually when you buy a rebuilt carb. they are the smaller one & nobody knows the difference. There are 2 different bolt paterns on fans. It originally had the large one but some water pumps are drilled for both. Universal fans have slots for any pattern.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#32367 02/10/2005 5:40 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Depends on what year 292 you're getting. The crankshaft flanges on the 1963-66 292s used 7/16" flywheel bolts and a single dowel pin. If yours has this then either the 230 or 250 flywheel (maybe even the SBC) should work with no problems. The 292s from 1967 on used 1/2 inch flywheel bolts on the cranks and had 3 pressed in dowel pins. The 292 factory flywheel holes are cast accordingly. So if you use another 6 cylinder flywheel besides the 292 on the '67 & up 292, you'll lose 2 dowel pins - even if you drill the bolt holes out to 1/2 inch. It's best to get the factory fitted flywheel. They appear on Ebay all the time. In fact, here\'s one for a manual transmission really cheap that's ready to bolt on (it's about $20 more than shops here charge just for resurfacing). -ftyler | | |
#32368 02/10/2005 9:21 AM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | I have a large ventura carb with very low miles. I just happened to get it buy a fluke. Usually when you order a rebuilt carb they for any six they give you the one for the 230/250 since those engines were the most common and those are the most common cores the rebuilders have. In my case I ordered a carb for a 250, and they gave me the larger 292 carb. However, I'm using a Holley/Weber, and plan to stick with it. Send me a pm is your interested. Boo PS Please don't tell anyone I put a pinto carb on my chevy
We don't need no stinking V-8s!!
#32369 02/12/2005 9:02 PM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | so i was wondering then, can a v8 flywheel fit the 292? are they the same?> | | |
