4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#32276 04/10/2005 7:11 AM
Ok guys,
I've installed a new okie bush (thanks for the help Dusty ) and uni-joint. I'm trying to set the shims. There were no shims installed when I took off the bell to do the driveline work. When I tighten things up with no shims the bell is still fairly loose. This is without the cork gasket in place. This leads to two questions;
Is the bell tension set with the cork gasket in place?
If not. Is the face of the bell so badly worn that I need to source another one?
This is a daily driver guys and I need this old beauty back on the road.
Cheers
Bob
#32277 04/10/2005 8:19 AM
Sorry guys I forgot to say that this is a 41 1/2 ton with 4speed box
Ta
Bob
#32278 04/10/2005 10:01 AM
The cork gasket sets the tension.
Paint & Body Shop moderator
#32279 04/10/2005 9:42 PM
Thanks Josiah. I can finish the job off now. I've missed chuffing around in this old thing.
Cheers
Bob
#32280 04/11/2005 1:37 PM
8
8 Offline
I don't like to disagree, but...My shop manual for the '51 says to set the tension without the cork seal in place. I don't see why it would be any different for your '41.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#32281 04/11/2005 5:49 PM
I agree with fab51. The cork seal will give you a false feeling of being tight but will quickly get worn out if taking the load and you will soon have to much play in the bell. If no shims leave the bell loose the seat area of the trans is most likly worn out. "National" seal company made a brass repair for that problem if you can find one or replace the trans case extension.
My Blog
#32282 04/11/2005 10:04 PM
Tim and Dave thanks for the input. I do have a spare tranny and tried the bell on the back of that. Same thing still a little loose. Is this a common problem on the 4 speed? Anyone else have any comments?
Bob
#32283 04/12/2005 1:27 PM
8
8 Offline
I can't speak about the 4 speed, but I ran into this on a 3 speed. I had a spare I was going to swap in while I had my motor out. When I checked the fit, it was plum sloppy. I checked the fit on the trans that was in the truck and fortunately, it was fine. It seems like a logical place for quite a bit of wear. The only thing I recall the shop manual saying about it is it may be necessary to replace the ball assembly. Now, to find a ball assembly...
-Tim
#32284 04/12/2005 1:57 PM
A few years ago, Jim Carter was selling a new 47.5-55.5 replacement bell/ball (but not the threaded collar and metal washer/ring). He might still be carrying them. For what years is the ball/bell the same part?
Tim
#32285 04/13/2005 10:37 PM
Thanks everyone for the help. I'm going to check out a source for some spare parts this weekend.
Cheers
Bob
#32286 04/14/2005 8:34 AM
Oops, my bad, I had it wrong and remembered that the gasket between the transmission and the bell housing is the tension setter. Sorry about that.
#32287 04/15/2005 2:37 AM
No probs Josiah. As always I just really appreciate you guys taking the time out to help.
All the best
Bob
