Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Woodcmiami, rfs56trk, Cosmo, cmayna), 37 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#32246 06/22/2003 4:14 PM
Pal
Offline
2nd issue arose with the new engine (250). The spark plugs I bought were the standard size for a 68 250. They screwed in normally, until I tried to put a socket on them. The socket (all that I tried) wouldn't fit deep enough to tighten the plugs. They are blocked by the heads side walls. Is there a diffent style socket I should use, ie. narrower profile? Or do I have to find a different style plug that has a higher nut?
35 + years of rollin' steel!
#32247 06/22/2003 7:02 PM
might be the plug brand, but there are thin and thick wall sockets - maybe look around your tool shops and compare what's available w/ what ya got - might need just a regular thinwall deep socket rather than an actual plug socket or viceversa
#32248 06/23/2003 2:19 PM
Custom tool time.
Got a bench grinder? Carefully grind down the outside of a cheap sparkplug or other deep socket to clearance around the head.
George
