| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32246 06/22/2003 4:14 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | 2nd issue arose with the new engine (250). The spark plugs I bought were the standard size for a 68 250. They screwed in normally, until I tried to put a socket on them. The socket (all that I tried) wouldn't fit deep enough to tighten the plugs. They are blocked by the heads side walls. Is there a diffent style socket I should use, ie. narrower profile? Or do I have to find a different style plug that has a higher nut?
35 + years of rollin' steel!
#32247 06/22/2003 7:02 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | might be the plug brand, but there are thin and thick wall sockets - maybe look around your tool shops and compare what's available w/ what ya got - might need just a regular thinwall deep socket rather than an actual plug socket or viceversa
Bill | | |
#32248 06/23/2003 2:19 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Custom tool time.
Got a bench grinder? Carefully grind down the outside of a cheap sparkplug or other deep socket to clearance around the head.
George | | |
