7 members (Hotrod Lincoln, mo2cyl, Woodcmiami, 66flea, DadsFirstPickup, 5 Window 9434, 1 invisible),
102
Mod | | | Forums66 Topics128,049 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32182 01/09/2002 6:44 PM | Joined: Jan 2002 Posts: 45 Member | | Member Joined: Jan 2002 Posts: 45 | On my 65 chevy pickup...i need to have the exhaust pipe replaced. I could go to a muffler shop and have make a new exhaust pipe for my 292 staight 6...four speed on the floor with compound low.
How ever i was wondering if there are already some places that have preformed OEM pipes?
Have already called up a couple of chevy old truck places and they didn't have any.
Any suggestions?
Starrider | | |
#32184 01/09/2002 6:52 PM | | Anonymous Unregistered | | Anonymous Unregistered | In the end you will have gottin a better job if you bite the bullet and have and ex shop do it for you.Heck i have a tubing bender and i dont do ex work.The guys build that stuff to cheap.Last daul 235 i did was 230 bucks out the door with new mufflers.So.....i bet a single would be pretty cheap unless you want stainless(that i do myself). Try for at least aluminized pipe and a good guaranttee muffler cause are stuff sits alot and rots mufflers from the inside out. | | |
#32185 01/10/2002 3:51 AM | Joined: Jan 2002 Posts: 45 Member | | Member Joined: Jan 2002 Posts: 45 | | | |
#32186 01/10/2002 11:21 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Starrider,
Don't take this as an Ad or Endorsement, but I had exhaust systems done on the following vehicles: 1950 Chevy Fleetline, 1961 Willys pick-up, and 1964 Chevy C-10, all at the local Midas Muffler place. Seems that their "limiting factor" was whether or not they had a "card" on the vehicle (spec-card?). Where they seem to get hung-up is on Y-pipes for V-8s and some flanges for older manifolds.
There are some folks who advertise vintage exhaust in Hemmings; I bought a "Y-pipe" for a '61 Plymouth from Keppich Exhaust in Florida, and it fit...
You're probably best-off finding a local guy to do it, if possible- easier than shipping stuff back to the vendor if it doesn't work.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#32187 01/11/2002 12:38 AM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | why not bag the y and just dual the exhaust? if it is that big of a pain a dual is going to be cheaper in the long run.(and who wants a single exhaust when the can have a dual?) | | |
