3 members (Otto Skorzeny, Shade Baby, 1 invisible), 102 guests, and 1 robot.
Topics128,154
Posts1,056,831
Members48,456
One of the exhaust studs on my daughter's engine is stripped. I need to pull it out and replace it. What's the best way to do this.
I tried heating it with a propane torch, sprayed it with 'Moov it' fluid and reeefed on the clamped on vice grip, but nothing. don;t think the big chunk of metal was getting that hot from the torch.
Thanks in advance for the help.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
Heat that stud up as hot as you can, take a candle and rub it around the threads. The heat will make the wax get into the threads and help get the stud out. If the stud is red, let it cool first before you try to take it out. You might need a bit more heat as well.
Heat the head around the stud with a propane torch so that it expands and loosens it's grip on the stud. I just get it loose and then soak it with penetrating oil to prevent damaging the threads during removal. Works every time.
Jason
Riding in the Passing Lane
I agree. Heat the metal around the stud to a
slight glow but dont heat right on the stud.
smile
1972 Chevy c10 Cheyenne Super
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
Thanks for all the suggestions...But I didn't make it clear that this is one of the downpipe studs on the exhaust manifold. Only one bolt holding her exhuast pipe on right now.
I'd forgotten about the wax idea. have to give that a try.
The heat should suck the wax up around the threads. Good luck, hope you don't have to get the drill out.
