1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | I have a 52 3/4 ton that I am going to use as a parts truck. It was upgraded to a 235 at some point and it has the 4 speed on the floor. The thing that surprised me is that it has a open drive line! Didn't the 3600 come with the torque tube as well? If it did then what kind of transmission do I have? The gear shifter looks totally stock and so does the rear end. Maybe I'm crazy but this seems pretty weird to me. | | | | | Joined: Oct 2001 Posts: 2 Member | | Member Joined: Oct 2001 Posts: 2 | The 3600 trucks had a two piece drive shaft. The front half was a closed tube like the 1/2 tons, the back half was open drive line to the rear end.I also have a 52 3/4 ton. Hope this helps.
Drive it, or sell it to someone who will!!
| | | | | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | Oh well, I was excited because I wanted to use the four speed in my 51 half ton and I thought I had a open drive line. I guess that ruins that idea. | | |
#3215 10/02/2003 10:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Nope, just take the extension off the 3/4 ton tranmission and the torque tube on the half ton will bolt up.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The 3/4 ton torque tubes use a larger u-joint and yokes which will not mate with the 1/2 ton torque tube. You will need to find a transmission yoke from a 1/2 ton which had a four speed.
Jason
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd find a differential from a later model with an open drive line and switch it over.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I just noticed on my daughter's '53 Suburban also has an open drive line with a short piece about 8" up front that slips in the transmission. I thought it may have been an after market modification so it could us an open drive shaft. So I take it that this is a stock drive shaft? Hum..interesting. | | |
#3219 10/04/2003 12:26 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | I'm sorry, what I meant was that I wanted to go to an open drive line and I thought the 3/4 ton transmission would work because I thought it was an open drive line set up. From reading basically all of the archives on this site, I have come to the conclusion that the easist way to go to an open drive line on my 51 half ton is to find a 55-62 transmission. Is this correct? I want to use a four speed with the granny first gear because I want to make this truck my daily driver and I may want to pull a boat or something with it one day. Even if I never pull anything I can use it start off on the side of a hill and what not, and save some stress on the clutch and the motor. So if I have my transmission needs figured out then the next step will be deciding on the rear end. I saw somewhere in the archives that some think that a 3.08 ratio is the best, while most of what I see refer to 3.55 as being the best option. I would think I could get away with the 3.08, especially with the four speed. What do some of you guys think? Thanks! | | | | | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Originally posted by Ingo Swan: I'm sorry, what I meant was that I wanted to go to an open drive line and I thought the 3/4 ton transmission would work because I thought it was an open drive line set up. Well, you *could* do what the 3/4 guys do: use the closed driveline, with the intermediate U-joint, and an open driveline to the rear axle. You'd have to install the cross member, liek the 3/4, but hey! it'll make the frame stronger. George | | |
#3221 10/05/2003 11:10 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Ingo Swan: I saw somewhere in the archives that some think that a 3.08 ratio is the best, while most of what I see refer to 3.55 as being the best option. I would think I could get away with the 3.08, especially with the four speed. What do some of you guys think? Thanks! I have 3.08 gears in the rear of my '55 1st 1/2-ton Suburban. I have a GMC 270 and a granny-gear 4-speed. It's great for light-duty work and will run down the highway at 70+ real nice, but its not so good with a trailer. I borrowed a friends implement trailer a while back to haul another truck, and empty it was enough load that I decided to use my V-8 powered truck instead. This is a heavy trailer, but empty it would not weigh what a loaded boat trailer would be, or what a lighter trailer with a car on it would weigh.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
