| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32134 02/21/2003 1:25 AM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Does anyone ever resurface the valve end of a rocker. This is for a 235. Ive looked in the search area of all web sites but only one ref, And they used the word GRIND. I DONT THINK SO. I know that ive seen it somwear. SO does anyone have any thoughts on this,  :confused: | | |
#32135 02/21/2003 1:55 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I just use an oil stone on mine ,, a few minutes work on each rocker seems to d othe job . | | |
#32136 02/22/2003 12:12 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The shop that I go to grinds them on, I believe the valve grinder. He showed me a set that had a circular indentation on each one that would make it impossible to set the valves. | | |
#32137 02/22/2003 2:11 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | If you can find someone with a Sioux valve grinder that has the attachment for grinding the valve end of the rocker arm they should be able to do you a good job of grinding it. You can do this free handed but it isn't as accurate as the machine. It is real important to do this so the rocker slides on the valve stem instead of trying to pull the stem sideways every time the valve opens.
kdot em3
#32138 02/22/2003 2:28 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | a quality sanding drum in a drill press works good if you're careful.Lay the rocker on its side on the drill press table, strike it on the drum with a rotating action, lots of fun. If you're extra anal, make a small jig to hold the rocker. | | |
#32139 02/22/2003 3:27 AM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | HAY GUYS Thanks for the responces, I guess after reading posts here and At other sites im going to be anel, not extra anel and build a jig.  . this helps stope things like the very popular self adjusting oil pump end play problem, and the anti-theft sparkplug in the starter linkage device problem. THIS IS IN FUN  . | | |
