| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32065 02/18/2004 6:33 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Does anyone know who sells the front division block for a 46 1/2 ton? The one I refer to is the one the by the front right tire on the frame rail with the outlets for both front lines?
No at the following... Jim Carter sells the rear one only.... Filling Station Chevs of the 40's | | |
#32066 02/18/2004 7:05 PM | Joined: Oct 2003 Posts: 17 Member | | Member Joined: Oct 2003 Posts: 17 | I've got one if you aren't in too big of a hurry. I will have to take it off and it is "COLD OUT THERE!"
No hill for a climber!
#32067 02/19/2004 6:24 AM | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | I don't know if this is what you're looking for, but Obsolete Chevrolet Parts has part number 594595 "Pipe Connector, Front 1/2 Ton" that might be it. It is listed along with a "Connector Tee At Frame" which I assume is the rear one. I checked American Classic and they don't list it.
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
