1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
Does anyone know who sells the front division block for a 46 1/2 ton? The one I refer to is the one the by the front right tire on the frame rail with the outlets for both front lines?
No at the following...
Jim Carter sells the rear one only....
Filling Station
Chevs of the 40's
I've got one if you aren't in too big of a hurry. I will have to take it off and it is "COLD OUT THERE!"
No hill for a climber!
I don't know if this is what you're looking for, but Obsolete Chevrolet Parts has part number 594595 "Pipe Connector, Front 1/2 Ton" that might be it. It is listed along with a "Connector Tee At Frame" which I assume is the rear one. I checked American Classic and they don't list it.
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
