6 members (1955 1 Series, Hotrod Lincoln, Eisenholtz, Otto Skorzeny, Hugh63c10, TUTS 59), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#32010 05/28/2003 11:21 PM
I am not sure where Brakes go in the forum, so I am asking in this room.
My brakes were mushy (53 GMC) so I bled them, didn't work and replaced the Master Cylinder, figuring after 50 years it was due. The new cylinder is not pushing any fluid through the lines...any idea as to the next step to find the problem? There are zero brakes now.
#32011 05/29/2003 12:43 AM
Did you bleed the new master and the system ? The mushy-ness would be air in the system and now you probably have even more air.
1951 1 Ton Completed
#32012 05/29/2003 3:11 AM
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#32013 05/29/2003 4:41 AM
thanks 53, that helps a lot. So plug the two exits and leave the cap off the reservoir and watch for bubbles? I take it the reservoir doesn't have to be sealed to build pressure.
#32014 05/29/2003 11:54 AM
That is correct. Some masters come with a couple of plastic plugs just for bench bleeding. The M/C will build pressure with the reservoir cover removed.. The key is to pump gently. As the bubbles subside you will feel the pressure build..
Bill M
53 GMC Hydra-Matic
Home Page
#32015 05/29/2003 6:34 PM
There is a little pinhole in the cylinder where you place the brake fluid...bet ya it's plugged, mine was...and that corrected the problem...I also had my shoes too far out, they have to be slightly touching the drums to be correctly placed to maintain pressure...
