3 members (1955 1 Series, Hotrod Lincoln, chevyb), 160 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#31986 01/14/2004 4:46 AM
Currently I have a SM420 Muncie 4-speed, and I was wondering if the SM465 has higher gears than the SM420. I assume that both have a 1:1 in 4th gear? Is there another good heavy-duty truck tranny I can swap in to get higher gears? Any 5-speeds? Thanks for any help.
'48 Chevy 2 ton Flatbed
(daily driver)
'70 BMW 2002
My truck is older than my parents!
#31987 01/14/2004 8:14 PM
The SM-465 is very similar to the 420 in gear ratios, and is a 1:1 transmission in 4th. The 89MM tranny has an overdrive 4th.
Paint & Body Shop moderator
#31988 01/14/2004 9:47 PM
You could always find an NV4500 - late model five-speed heavy-duty truck transmission. Overdrive fifth.
1954 GMC De Luxe COE
#31989 01/15/2004 1:55 AM
the SM 420 has the lower 1st gear than the 465and if your using it in that Willys they are almost indestructable and will give you the crawl ratio you want. however the parts are getting a little hard to find when you break something, the 465 is a little bigger and stronger and the parts are available but 1st gear is not as low . Both trans are 1to 1 in high gear so no advantage is picked up on the big end. The NV 4500 is the hot ticket with compound low and overdrive. But it is expensive. Tony
#31990 01/15/2004 2:42 AM
The SM420 has a 7.06 first gear and the 465 has a 6.55.
#31991 01/15/2004 4:20 AM
For tranny facts go to the Novak Tranny Page .
The 465 is bigger and heavier, requires machining out the round hole in the bell housing to put on an older GM truck.
If this is for your flatbed, Jolly has pu an auxillary gearbox in one of his trucks. Here's the link 12 Speed 1 ton
Fred
52 3600
69 C-10
