7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel),
94
Mod | | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31879 12/09/2003 2:16 AM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Hey Guys...I have a '59 1/2 ton chevy and I'm in the process of putting the ring gear and pinion back together. I think I mixed up the bearing caps though. Do any of you guys know what the casting #'s are for the left and right side? It looks as though somebody might have notched them quite some time ago, but I'm not sure. Can anyone help this 26 year old kid who started a restoration exactly 1 year ago today!!
Also I have the proper clearence .005, but it has a "Toe" pattern. Will this be ok for a casual driver?
-pork
1959 Chevy Fleetside 3100 Series BBW
#31880 12/09/2003 2:19 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would fix that toe pattern, it may give you problems.
#31881 12/09/2003 7:28 PM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | If you don't know which cap goes where, the easiest way to tell is to leave the carrier out, install the caps and feel the area where the bearing goes. If there are no steps where the bearing goes then you have them on correct. I would switch and try it again, then pick which way feels the best. Good luck!!
kdot em3
#31882 12/09/2003 8:08 PM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Pork: I just completed replacing the ring & pinion on my front 1/2 ton differential (it is the same as the rear). I can check the casting numbers on them tonight. On mine, there was one punch mark on one cap with a corresponding punch mark on one carrier side. The other cap had two punch marks & the corresponding punch marks on the other carrier side. I used that to maintain their relationship. However, I don't remember if the punch marks were originally there, or if I put them in prior to disassembly, you might check that. In any case I'll check my casting numbers for you tonight. | | |
#31883 12/09/2003 9:02 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Guys thanks for the input.
Donsz.....I anxiously await your reply with the numbers.
racecarldad....currently their is a little step, i will switch the caps and see if the caps become more flush w/ the carrier....
-pork
#31884 12/09/2003 9:27 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hey Pork , the parts book lists the carrier and the caps as an assembly , just one part #. So I guess the caps are machined as a match to the spot they are installed in . Hense the need to mark their respective locations before disassembly . Check those notching marks again. Toe contact indicates lack of backlash . Move the ring gear away from the pinion by loosening the left hand adjusting nut and tightening the right hand adjusting nut. Be sure you are not confusing toe contact with face contact , it is easy to mix those indications up. Face contact needs a thicker shim under the rear pinion bearing to correct it . | | |
#31885 12/10/2003 5:25 AM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Pork: I checked my end cap numbers; looking from the back (ring end facing you), with the carrier situated so the the ring is on the left: - The cap closest to the ring or left side is marked as: 3652335 *D17 - Right side is: 3652335 *D19 Again, this is from a 1/2 ton Napco front differential, but it is the same as the rear. And I believe that is the same as a regular 1/2 ton ring & pinion set. I don't know if this helps, because my shop manual & the instructions from Patricks agree with what Dusty & others have said; the end caps are machined for a particular side. So it is possible that the part numbers are relatively meaningless. Good luck. | | |
