4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#31838 07/23/2004 7:46 PM
U
Junior Member
Junior Member
U Offline
I have the opportunity to get a rearend from a 55-56 3600 Chevy truck, 8 lug with 4.56 gearing (I think) question is can I replace my 1 ton 5.14 rearend with this? as long as the width is adequate.
#31839 07/24/2004 3:08 AM
If it were a 1/2 ton you would have to move the spring perches from the top to the bottom of the axle housing then compensate for the '49 mounts being offset. I don't know if this applies to the 3/4 ton Task Force and 1 ton AD. That's the first things I would look at.
#31840 07/25/2004 1:19 AM
Easier than a total rear end swap is a pumpkin swap. Pull the axles and unhook the driveshaft. Then remove the center section out of the differential (from the front) and swap. You can get new gaskets at your local parts store. Same gaskets up to 1972 for a HO52 10 bolt.
Fred
52 3600
69 C-10
#31841 07/26/2004 9:16 AM
even better is to find a 4.10 or 3.9 geared one. They are around. I did that swap on my 5.26 and it was a huge improvement. I can go 60 now without stressing the motor (a newer 292).
And it is an easy swap - unbolt the old cover - let the goo out - unhook front ujoint - undo the axles and pull them out a few inches. Then unbolt the old gear set, and bolt in the new one, replace axles and covers. Instant gearing.
However, be careful of the axle seals. Mine soon went out (but could have been about to go anyway) and had to be replaced, but was not hard - and the seals were $7 a throw at NAPA. (Fits like 47-73 chevy truck....)
