5 members (dbwr, MickeyP, Gdads51, Steelonsteel, 1 invisible), 22 guests, and 8 robots.
Topics128,013
Posts1,055,312
Members48,419
#31818 11/19/2001 3:48 AM
Ever since I have purchased my 53 chevy truck
it had always got stuck in 2nd gear..It will
not come out, only if I stop.I have adjusted
my linkage and and tightened it up so it
would not be sloppy. What's up with it..?
How much oil does this transmission hold?
Thank you in advance..
1946 chevy 1/2 ton panel
1937 ford coupe
#31819 11/19/2001 6:17 AM
I had a similar problem with a '54 **** I once owned. The problem there was that the transmission kept coming loose. When it came loose, it would sag in the middle (where engine/trans come together) and somehow cause the linkage or trans shaft itself to bind. If I jacked it up a little so the engine/trans came together it worked. You might want to make sure the bolts are the right size with good threads and tightened up good.
My father had a '50 GMC truck when I was learning to drive. It would not go into first gear if you stopped with motor running so you had to double clutch, rev to match engine/trans speeds and shift it into first gear while still moving at 5-10 mph. Never did figure out what was wrong with that. But, I sure learned how to downshift without a clutch on that truck!
#31820 11/19/2001 6:19 AM
2nd isn't the best gear for the tranny's. My 4sp in my '50 3/4T Chevy, always get's stuck in 2nd gear, so I start the truck in 2nd cuz it'll shift up most of the time, but it wont come out when I want to go to first, and it's hard to put it into 2nd anyways. The tranny does need a full rebuild but that's $2000+ so I'm swappin in a T5 5sp out of a S10. If I can find one, I like the manual trannys, they're more fun than the TH350 I have sittin in my garage. Do you want to keep the tranny?
Nate
If you're clean, then you're not a 'Man' If your truck is clean, then your truck is a 'Queen'.
50 3/4T Chevy until it is traded or sold
48-55 1/2T Chevy parts until they're all gone
#31821 11/19/2001 6:30 AM
Well I'd like to keep it as orig. As possible
I picked up another tranny last summer. I
might try a swap and see if it works any
better. But I sure would like to know why it
sticks in 2nd like that.
1937 ford coupe
#31822 11/19/2001 7:42 AM
I don't know the real reason as to why, and I probably wont ever, but I've seen a lot of these tranny's with problems around second and know a lot of people with the same problem, but nobody really knows why they do it. Maybe a factory defect that happens after years of use or just a usually thing that goes wrong???
Nate
#31823 11/27/2001 4:27 AM
$2000 for a 4-speed rebuild? I was considering having mine rebuilt, but I had no idea it was so pricey. Maybe I'll go with the 5 speed also. Will it bolt up to the 216 in a '52 3600?
Tucker
#31824 11/27/2001 5:43 AM
Ok, I'm new at this. I just found the tech tips section with an article answering exactly my question. This is an amazing resource.
