| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31763 04/16/2004 9:52 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I'm attempting to replace the brake and clutch pedal felt pad seal and the replacement felt pads are about twice as thick as the slot to put them in. Do i have to seperate the felt to make it thinner? I appreciate any help. :confused: | | |
#31764 04/16/2004 10:14 PM | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | I put some silicone spary on mine and kept working until I got them in place, used a screwdriver to help spread them out after in slot. | | |
#31765 04/16/2004 10:30 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I'll give it a try and let you know how it works. | | |
