2 members (parklane410, 78buckshot), 60 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#31552 06/13/2002 12:06 AM
Hello All
I was just given a '48 Chevy 3/4 5-window Deluxe as a birthday present from my new wife... little does she know what she started... Anyway, I have lurked around these pages for the last couple of weeks, reading past posts and now am ready to jump in...
Beaulah May (the truck... not the wife) I am told has a '54 235 in her that was recently rebuilt. I have ordered the shop manuals and such, and they're on their way, but I was hoping to do her first tune-up this weekend.
Can anyone give me the basic specs I need for a simple tune-up? Quanity of oil, spark gap, that sort of thing...
Boswell
'48 Chevy 3/4ton 5 Window Deluxe
#31553 06/13/2002 12:29 AM
Congrats on the new (old) truck!
Here is some specs of the 54' 235 6 cylinder engine.
Breaker points:
.015 gap
Ignition timing:
2 degrees ATDC
Spark Plug:
#44-5 type, .035 gap
235 Firing order:
153624
Engine holds 5 quarts of oil.
When doing the timing, make sure the points are set first. And the vacum line needs to disconnected from the dist., when you time the engine. When timing the engine point the timing gun at the hole above the starter on the bellhousing on the pssenger side.
I hope this helps.
Chevyboy62
My truck don't leak oil, it just marks its teritory.
#31554 06/13/2002 3:40 AM
Boswell48,
The 1954 Chevrolet Truck Shop Manual and the 1954 Truck Operators Manual have almost the same specs for tune ups.
Distributor point gap: 0.019" new points; 0.016" old points (the cam follower on the points will wear down on a new set of points). Lubricate the point cam with vaseline.
Carburetor idle speed: 450-500 rpm by adjusting the throttle stop screw.
Carburetor mixture: turn idling screw (mixture screw) to give highest reading on a vacuum gauge (17-21 inches). Reset idle speed and recheck the mixture.
Ignition Timing: match the pointer on the flywheel housing to the ball on the flywheel (neither manual says to disconnect the vacuum advance line but if you do disconnect the vacuum advance line be sure to plug/seal the carburetor side, to seal the vacuum leak).
Plug gap: 0.035"
Valve tappet adjustment (Operators Manual): 0.010" intake; 0.020" exhaust (however, the Shop Manual says 0.006" intake and 0.016" exhaust - I use this setting on a hot engine). Check out the procedure here: http://www.thevirtualgarage.com/bboard/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=002575
The radiator cap should be a 4 lb pressure cap.
Tim
#31555 06/13/2002 7:15 PM
Thanks Guys... that should get me started. Then we'll start into all the troubleshooting and restoring questions.
If you have a dwell meter 38-45, confirms the points gap......
welcome aboard
chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Nineteen year old thread?
AD Addict & Tinkerer
Originally Posted by Justhorsenround
Nine year old thread?
Better add another 10 years on to that! LOL. What’s funny is I read the entire thread and didn’t pick up on that!
Phil
Project Journals
Stovebolt Gallery Forum
Nope, nineteen year old thread! I'm as surprised as you are!
Ron - - Dusty53
1954 Chevy 3604
Brain quit working. dang
I didn't pick up on the date of the thread- - - -but I was a little amused that people were giving out tuneup specs for a 1948 216- - - - -for a '54 235! Back when I was teaching school they had a program known as "RIF"- - - - -Reading Is Fundamental! Looks like some folks needed to go back to school!
