2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
Fellas, a friend is doing a 216>235 swap. The 235 is from a 57. Are there clearance issues with that swap? Water pump ? Any input?
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Water pump may be an Issue. I believe that some of the Exhaust manifolds output is different. Some are straight down and some are angled back. Other then that it should be a simple swap.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
You will need a short shaft water pump, the later 235 pump is different. Another problem is the carb linkage. If you have the 235 bellcrank and linkage it will be easier than adapting the 216 linkage.
Fred
52 3600
69 C-10
